L
Larry French
I have a 1980 Catalina 30 which I purchased late last year. I recently took a close look at how the sail is attached to the mast and it just doesn't make sense. The top half of the sail is attached with shackles to the inserts (not sure what they are called) that go up the mast. On the bottom half most of the sail is attached to the mast with a rope that goes through the sail (the little holes) and then attached to the inserts. This just doesn't seem right. My theory is that the inserts on the mast have broken off (or the shackles have) and rather than buy a few more pieces of hardware the owner just used rope to attach the sail. I'm thinking that I need to buy more shackles and inserts. Is this correct? Another issue is that the top half of the sail I understand. The holes where the shackles are inserted are evenly spaced. On the bottom half, however it is a different story. In one location there are three closely spaced inserts. Do all three need a shackle? How do I pick the right one?Thanks,Larry
