Sailing with no furling winch
Apr 8, 2011
774
Hunter 40 Deale, MD
I couldn't find a single device that is all of a ratcheting block with stantion mount and ratcheting, so my first change will be a non-ratcheting cam cleat block
Like these? You could use the ratchet block, and still use your cleat when you're done with the furler adjustment.
92088-STANCHION MOUNT RATCHET BLOCK LEAD | Nautos-usa
57mm Ratchet Stanchion-Mount Block | Harken Marine
A cam cleat ratchet block will require this and hardware to connect the two::
Stanchion Mount Base | Harken Marine
Others have probably done this and can comment. Good luck.
