It sounds like he had a bit of confusion over the specifications of his boat. I think he mentioned that his mast is just 25'. I immediately wondered if he was distinguishing between the length of the mast and the air draft, which is 2 entirely different animals (unless the mast is a keel-stepped mast - the keel mount and waterline
may be
close to the same level). But the real issue is that I think he is confusing the mast length between the 22' Typhoon
Senior and the 19' Typhoon
Weekender. Based on the videos and your earliest description (22'), he definitely has the Senior model. The "P" dimension of the Senior is 27.5' based on Sailboat Data. Add approximately 6' to the waterline from height of the boom and his air draft is at least 33.5'. I'd say that even a 35' bridge clearance could be a little sketchy if there is any inaccuracy in either the stated height or the water board reading when he is crossing under.
BTW, the Weekender mast length could very likely be 25' as he stated based on the published P = 22' and an additional 3' for a deck-stepped mast. But the length of his (deck-stepped) mast for the
Senior model is at least 30' to 31' in actual length (as he measured, I think) based on the published information.
It looks like he made it to Atlantic City at the end of his latest video. At one point he mentioned Manasquan Inlet as the start of his ICW route. I hope he didn't intend to continue along the ICW from A.C. to Cape May. I'm pretty sure that his water draft would be fine, but his air draft won't make it by the Sea Isle City fixed bridge or the Avalon fixed bridge. There are a few other fixed bridges at 35' height and some bascule or swing bridges he could get through but I doubt that he will be able to make it without going outside into the Atlantic. But he has already made it this far, so I'm sure he got by those obstacles by now. Looking forward to the following episodes!
So he experienced the Pt. Pleasant sleigh ride! Here is a little taste for your enjoyment!
Watch videos instantly on Bing—enjoy direct playback, discover related clips, and dive into trending content all in one place.
www.bing.com
