Sailboat Owner's Guide to Corrosion - Protection (Collier 13 - 15)
JamesG161
Feb 14, 2014
8,017
Hunter 430 Waveland, MS
The table includes many alloys and only a few pure elements.
Most metals are alloys on our boats.
Copper tubing and wiring is the only one pure element that comes to mind.
Collier has a fair amount to say about plastics and elastomers (new word for me, natural and synthetic rubbers/neoprene).
He talking about electrical insulators. These materials can be used to prevent an electrical connection between two dissimilar metals.
Thermoplastics are non-cross-linked polymer chains and get soft when heated at relatively low temperatures. These include polyethylene, polystyrene, polypropylene, nylon, PVC and some polyurethanes.
Thermo setting plastics are cross-linked polymer chains and more rigid than thermoplastics. They include epoxy, polyester, silicone, some polyurethanes and rubber.
Plastics can be hygroscopic, meaning they absorb water. This can change them by making then softer and can cause them to swell.
For the most part, however, natural waters, those we find while boating, have little effect and are used for all sorts of things on boats.
The next chapter, 15, covers coatings as electrical insulators for metal parts.
-Will (Dragonfly)
I wrote, Collier covered coatings as electrical insulators for metal parts, but that's not a complete picture. The first part of the chapter is on metallic coatings. They can act either as or both as electronic insulators, removing contact with the electrolytic, and as sacrificial anodes.
When I first took my pock marked centerboard out of Dragonfly, I thought I might want to coat the cast iron in lead. Smooth out the surface and add a bit more stiffness to her righting abilities. Not being familiar with the process, I opted to go simple and use just a high build epoxy-based barrier coat.
It seems the lead might have been an excellent choice. Lead has a very high resistance to corrosion and it would have isolated the iron very well. I would have still painted it with a barrier coat to protect the lead from physical damage.
All other coatings, Collier dumps in under "Organic Coatings". He has some very interesting things to say about all of them. The chapter is a great resource for information on different coating options availible. As far as the applicability to corrosion protection, the basic concepts are fairly simple. For features like adhesion, ease of application, air/water permeability, and other stuff, it's worth a read. He tells you a little about their composition, where they are generally used and for what. There's a lot here, even as a general survey of what coatings are availible.
-Will (Dragonfly)
dLj
Mar 23, 2017
5,069
Coatings is a huge and very dynamic field. One of the recent NACE publications shows lots of chatter about coatings...
Your lead would have worked. I think it's been outlawed since 1978, at least lead paint use in homes has been. I used to buy a primer that was essentially loaded with lead that you painted on the exposed steel and then did a top coat once dried. I can't remember the name of that primer. Worked very well, but sure was not fun to work with for recoating...
There is a lot of research being done in organic coatings. There are some amazing coatings out there.
dj
  • Helpful
Collier's section on Rust Preventatives was kinda fun to read. He wrote about what the old timers used and how they would go on about them. Considering how old Collier was when he wrote this book, I have to wonder who he considered an old timer. :what:
He mentions Cosmoline as a basic petroleum-based coating used up to the Korean War with origins all the way back to the Civil War. Then he points to a product called Rust Veto 342, which is the modern version of Cosmoline by the same company.
This is Cosmoline from Amazon.
There are all kinds of these comparative test pictures on Google. Most seem to center around preserving firearms, but the picture below typifies the kind of results I found pon a number of sights.
Collier also describes a couple of homemade rust preventers. He likes a concoction he called 'Magic Magoosallum' , made of a gallon of boiled linseed oil, a pint of turpentine and a pint of pine tar. A coating for all purposes, including an undercoat for wooden spars and hulls.
-Will (Dragonfly)
  • Helpful
Likes: JamesG161
I've been reading a bit into chapter 16, Hull Corrosion. Initially, it was to be skipped over, along with 17 on propulsion systems. Chapter 18 was included in this thread. Chapter 18 is titled Electrical and Electronic Systems. I'm going to change the plan a little. I'll start a new thread to include chapters 16 and 17; I'll title the section Hull and Motor. 18, I'll lump in with 19, on plumbing, then return to our previously outlined sequence.
If anyone had any objections, thoughts or suggestions, be sure to let me know. All options are open.
-Will (Dragonfly)
