sail trim for cutter question
Debra B
I understand where mainsail travelers should be set, what about staysails? my staysail has a pin-stop traveler, but I usually leave the car in the middle of the traveler. What is best for sail trim? should I think of making this a windward sheeting type of setup, or let the car move to leeward as I tack?
A
Alan
It depends on what you're looking for
Set it and forget it is NOT my game, but it is for a lot of folks. If you want to trim it right then put in a way of making the adjustments easy. Going forward to change the pin settings wont cut it. That's why you set it in the middle and forget it.
Debra B
but should the sail be upwind of the centerline?
I know I don't like the set it/forget mentallity, but making this change possible from the cockpit will not be a no-brainer.... How are the sails supposed to be trimmed? Would a windward sheeting system be appropriate? Or does the sail work better to leeward of the centerline?
