Sail Track Gate
Ferg
Mar 6, 2006
115
Catalina 27 C27 @Thunder Bay ON Ca.
So, I’m looking into getting this gizmo for my mast. Does anyone have it? Do you like it? Are there any install tricks or warnings I should know about? I found it on the front page of Catalina Drirect. These new gates: Provide a transition across the mast track sail entrance slot Allow sail slides to move past the entrance slot for reefing Reef right down to the gooseneck from the security of the cockpit Prevent slides from falling out of the mast track when the sail is doused Also, has anyone got the spreader mount upgrade from Catalina Direct? Stainless steel weldments, The lower shroud tangs are fitted to the same location as your old ones so your existing lower shrouds can be used. What the installation difficult? Any handy hints for this job? Later, eh! Ferg
The sail track gates are almost a must-have
for easy reefing, especially if the reefing lines are led aft. On our old C25 I never put the gates in because the reefing lines weren't led aft. I'd drop the halyard to a pre-designated marked spot from the cockpit, far enough to get the cringle down just below the hook, and hop onto the cabintop. Only after I took the sail track stop out and dropped two or three slugs out of the track could I put the cringle onto the tack hook and then pull in the clew with the reefing line which was led along the starboard side of the boom. Then I'd re-raise the halyard from the cockpit. To un-reef, I'd do that backwards. With the mast gates (which were originally made by a great guy named Joe from Texas many years ago for C22s as I recall) you can run the lines back or use the old way with less fuss and mess. There's the other way to do it where there is a line tied around the bottom few slugs which allows them to drop out of the way without the mast gate and leaving the track stop in place. I saw it mentioned here within the last six months, but I'll be danged if I can remember the name of the device (simple lines run through the bottom slugs for reefing). Either way (gates or lines) you can reef from the cockpit without the slugs falling out, and also able to re-raise the sail without going forward again. The mast gates, as I recall, are pretty easy to deal with. The C25 website guys'll explain it all, and they have improved their search engine recently, so you may want to try there, unless your C27 Association website is good for it, too. (C25 'site: http://www.catalina-capri-25s.org/forum/forum.asp?FORUM_ID=3) The spreaders were originally discussed and probably initiated and designed by the C30 guys, since the early boats had wooden ones, and their website should answer those questions. www.catalina30.com -- why .com, I dunno. As far as general installation, heck if someone else who owns a Catalina can do it, so can you! :) [Nice to see you "over here."]
Ferg
Mar 6, 2006
115
Thanks Stu!
Yep, the installation looked simple enough, and as always, I appreciate your input. I was sort’a hoping somebody had these things and give a little critique on how the perform. I will check the association sites, I’m just loyal to this one….. Safer reefing is the goal. I’ve got my reef lines run to the coach house roof, but somebody still has to scurry up to the mast and pull the pin. See ya on the “dark” side ! Ferg
