The drain screw for the sail drive was a pig to remove. The wide range of special oils and freeze spray were useless and it came down to a mother of a screw driver and brute force.
I will be replacing the old with a new drain screw however I'm thinking that there might be something that can be applied to the screw threads. Was thinking teflon tape or anything that you all might suggest.
Thanks
Thanks
