S2 9.2a new owner
Dec 12, 2021
10
S2 S2 9.2a Raritan Bay
Ahoy there,
I have just purchased 1978 S2 9.2a with a 2GM20F Yanmar. The boat is in a great shape. I love the cabinetry and simplicity of the rig. I gutted the toilet system and I am doing small tasks here and there to make her ready for the next season. The main was reinstalling rudder to change stuffing, lower the drive (Edsom wheel drive) to correct alignment of the steering cables and adding bushing/bearing rudder stock retaining ring. Electronics will have to be upgraded since having accurate depth finder would be critical to my survival where I sail (I have a 4'11" draft version). I have a questions for all of you who own the same boat. Where and how is(are) transducer(s) placed on your boat? Mine is glued in the storage area under the port lazarette. I am contemplating drilling 2 inch hole in the bottom of my boat to mount in hull transducer but I am having nightmares about that. Any thought about doing that versus staying with in hull glued version?
JP
1978 S2 9.2a
"Tenacious Lucille"
May 1, 2011
5,563
Pearson 37 Lusby MD
Not an S2, but . . . My speed wheel and depth transducer are installed forward of the keel. Many folks have what you're calling an in hull glued version and feel that it works well. And it's one less hole in the boat!
The “in hull” or also called “Through Hull” transducer works very well for sailing depth reporting. Maybe if you were fishing and needed to know what was happening 300feet below the boat an exposed Transducer would be worthwhile.
Dec 10, 2024
2
S2 9.2C Georgetown, ME
Hi there. I'm currently in the process of buying an S2 9.2C (center cockpit) berthed in Maine. My transducer and log paddle wheel are on a small bumpout on the hull, accessed thru a small hatch in the cabin sole.
Interested in your rudder/binnacle issues - my rudder is frozen, I suspect water got into the top of the rudder at the shaft sleeve and froze there (it's winter in Maine!). I will need to take care of that somehow.
