Running a fan on an inverter
821
Marine Trader 34 Where Ever I am
Benny
Sep 27, 2008
1,149
Hunter 320 Tampa, FL
For overnight usage I would go with a 12V fan. As to what unit, it all depends on the amount of use you intend to give it. If you overnight often and intend to use it a lot get a quality fan. On the other hand if you will only use it occasianally you may want to go with an inexpensive clip on. The Walmart automotive 12V fan draws 0.8 amp per hour and sells for around $10.
2,288
C30 Event Horizon Port Aransas
I gaurantee you if I bought a fan with out a gaurd on it I would stick my head in it with in the first hour of installing it.
We got one at an auto store, 12V cigar plug, bought an extension cord. It also rotates! $10!
12V is a no brainer - don't use the inverter.
Jul 20, 2005
2,422
Whitby 55 Kemah, Tx
oh yeah....forgot to say, the auto one is also louder so it's hard to sleep with compared with the Boro fan.
May 23, 2004
3,319
I have two 12V fans in my boat. One West Marine one that tends to blow a descent amount of air and then one that is mounted in my V berth that really don't move all that much air. That being said, the one on the V berth isn't that expensive and it does move enough air to help with hot temperatures. I also like the white noise of a fan running so I tend to run mine a lot.
I have a two battery house bank that are group 27s. I do not run refrigeration on my boat so there isn't much power consumption going on. I have my house bank on a Link 10. I can run the fan in the V berth all night, the cabin fan for most of the afternoon, a small inverter to power the lap top, and the anchor light and I am usually at 98% or 97% in the morning when I get up, according to the Link 10.
Dec 19, 2006
5,818
Hunter 36 Punta Gorda
Cheap fans
The cheaper walmart type fans are a bit noisy and don't use at night I also have three marine type for at night,was in WM recently and they have some new fancy fans that really push some air yes they are $$$$$ but you get what you pay for.
Nick
Mar 8, 2009
530
Catalina 22 Kemah,Texas
I have the honeywell and the same inverter, I just ran it for three 8 hour nights. I'll have to check the batt voltage. I also ran a 9 watt compact flourescent for an emergency anchor light when mine failed to work.
Jan 5, 2009
40
Hunter 28.5 Lake Lanier
The fan is noisy but moves a fair amount of air.
I find it somewhat inflexable in the angles you can adjust it to once it's clipped on to something.
Probably worth the money, but the shipping cost made it a bit of a dud for me.
Jun 6, 2004
173
Catalina 38 San Francisco Bay
O2 COOL Fans 12V
This is a delayed response, but I have become fan (pun intended) of these fans. They draw very few electrons and quietly move a lot of air. They can be run on D-Cell batteries or wired or plugged into your 12V system. The price is far below anything you will find at the marine supply stores. Some are even meant for outdoor use. I found mine at my local Drug-Store for less than $20. Lowes has them as well.
http://www.coolfansonline.com/servlet/Categories?category=10"+Battery+Fans
http://www.coolfansonline.com/servlet/StoreFront
PKFK
Jul 12, 2004
206
Hunter 36 Ottawa
Carframo Fans are excellent....
We use one of these:
http://www.caframo.com/marine/marine_products_12voltfans_kona817.php
It is 3 speeds and draws 0.21, 0.26, and 0.37 amps on low/med/hi.
The fan moves quite a bit of air - waaay more than the ones that run on 4D cells.
Current draw is almost negligible - I run a 260AH house bank (also with refrigeration - Isotherm ASU - which also is super efficient).
Running the fan on HI for 12 hours only consumes 4.4 AH.
For me - the "air moved" vs "power conservative" equation makes these fans great for cruising.
Paul
