After the boat was on the hard we determined the lower bearing to be good (passed the shake test). After removing the Edson radial drive wheel off the rudder post we lowered the rudder about a foot on to a piece of cribbing. To remove the rudder you have to have the crane pick the boat up another 5 feet or dig a hole below the rudder if at home. I'll have to do that for cutlass bearing replacement soon. There is a spacer that the drive wheel rests on, which also rests on the deck. The upper "donut" bearing is below the deck, bonded into the fiberglass rudder tube. The opening in the deck was maybe a 1/2 inch bigger than the post, but too small to pull the bearing, so we opened the hole in the deck to get at the 3-in OD bearing. After R&R of the bearing, we bonded a piece of material over the opening so the spacer could again ride on the "new" deck. I'll put together a document with pictures and see if I'm allowed to post it in the Hunter Owners Modification section and let you know. I wanted to document several other mods and major maintenance that included mods, like the Air Condition unit, engine compartment blowers, mast and rigging rebuild, upgrading the mast lightning ground, pulling and replacing the compression post, head gate valve, plumbing and a few others.
