Rudder Play
Paul
My Beneteau is up on the cradle. I have noticed a bit of up and down play in the rudder...about 1/4". Should I forget about it and go sailing? Just how much play is considered good? Can I make the adjustment? Thanks
john
play
have a shim made to the top of the rudder. there should be but a 1/16 of an inch at the most.
Dec 3, 2003
2,101
Where is the Slack?
Trace back to where the slack occurs. Maybe the pin that passed thru the quadrant/rudder stock is worn. Or maybe the hole in the rudder stock that the pin passes thru is worn. Somewhere, the slack happens - and shouldn't. There should be no movement in your rudder. You could have a very unfavorable experience. Good Luck!
H
higgs
Check out others
This is when I walk around the yard checking other boats to compare with mine. Remember your rudder floats when the boat is in the water so it will be in the up position.
