Rudder On or Off When Trailering?
1,041
Hunter 27 Cherubini Alum Creek State Park
Catalina 22, going less than 10 miles.
Knowledgeable advice welcomed.
Thanks.
Oday 35 and Mariner 2+2 Alexandria, VA
Do you need the extra steering?
A short trip, I would say lash it and go slowly. Anything approaching highway speeds for any length of time, it may save sanity to remove it.
Sep 2, 2011
1,041
I'll be doing 50mph max.
Sep 2, 2011
1,041
Squidd said:
OK....Never mind...:redface:
Sorry about that K word. I've come to understand that word is not in the sailor's lexicon. ;-)
Oct 6, 2011
678
CM 32 USA
If it comes off easily, better to take it off before the trip, than to go back looking for the pieces. On my Mac 25, I always removed it. On my 32's, they do not come off easily.
Sep 2, 2011
1,041
It's supposed to come off easily, but it doesn't. On my last boat, I just left it on, but it had more substantial gudgeons.
The "looking for the pieces" quote may just sway me to go to the extra trouble.
Oct 19, 2009
97
oday 22 Lake New Melones
I always remove the rudder and outboard when trailering. Even though they are both heavy and PITA. I just don't think the stresses, bouncing, vibration from the road would be good for the transom.
kenn
Apr 18, 2009
1,271
CL Sandpiper 565 Toronto
We trailer with the rudder off and stowed in the cabin. I also take our outboard off when trailering. But when we're trailering, it's usually long distance, and I just don't want things hanging off the transom.
(Also, I did alotta work to make our mahogany rudder all clean and glossy. It's my baby)
For a short distance like 10 miles... unless the road is terriblly rough, I wouldn't be afraid to trailer with motor and rudder on the transom (and secured), as long as I can baby it by going under-speed and cautiously.
May 21, 2009
362
Hunter 30 Smithfield, VA
I always removed the rudder on my 73 C22. It wasn't difficult though. Still, the bouncing etc. from a trailer are stresses the gudgeons wouldn't see in the water. Worth the peace of mind to remove it. JMHO.
Dec 20, 2010
294
Yankee Condore 21 Halifax
Rudder OFF
I'd be worrying about the goof behind texting or calling on the cell when I made a stop. It wouldn't take much of a hit to do major damage to the transom, plus the stresses on the transom while trailering seem to make it not worth while.
c_witch
Nov 23, 2011
2,023
MacGregor 26D London Ontario Canada
I had a buddy pick up my boat and drag it 650 km for me. I told him to make sure the motor and the rudder were in the cabin of the boat. (I gave him a detailed list.)
It showed up with both on the back and a trailer light dragging. Not to mention the only thing holding the boat to the trailer was gravity!
I will be removing the rudder and outboard when ever I go any distance more than up the ramp to the set up area.
Mar 8, 2009
530
Catalina 22 Kemah,Texas
definitely off, there is not a lot of clearance between the rudder and the road if you go through a dip in the road, especially when the rudder is ten feet behind the axle.
Oct 6, 2011
678
CM 32 USA
With friends who needs enemy's as the old saying goes.
Jan 24, 2005
4,881
Oday 222 Dighton, Ma.
I take my rudder off and stow it in the bed of my pick up truck. I leave my outboard on the bracket when I trailer. I usually tie it off to my stern rail for extra support.
I not only have my outboard clamped to my transom bracket but I also have two bolts holding it to the bracket, an 8' charging wire going through my inside transom connected to a terminal board under the lazarett cover. I've always owned and 8 hp Johnson and trailered my boat with it on the transom since the late 1980s and never had a problem.
If you have trouble with the pintles and gudgions, you need to correct it some how in order to make it easier to get your rudder on and off. They may be out of alignment or just need lubing. Whatever it takes you should correct it and stow your rudder in the back of your pickup or trunk of your car. I keep my tiller in the cabin of my boat with the bolt and wing nut for easy mounting.
-na -NA Anywhere USA
Gorilla Toast;
I have probably trailered different sailboats on their trailer over two million miles in my life time. If you are planning to trailer particulaly long distances plus you are concerned, then by all means take the strong advice of many and remove your rudder.
There are some cases that it did not pay to remove the rudders and that was on for example the Hunter 260. I use to instruct my customers to swing the rudder to one direction all the way and tie if off to the base of the stern rail making sure the line was taunt without slack even though there was a pin to hold it up. Worked everytime for me except only once when I forgot to tie that rudder up. On the way to deliver the boat, a trucker honked and I pulled over. I had the most beautiful sawed off rudder due to the contact with the road surface. Thank goodness I had one in reserve to save the day.
crazy dave condon
Jun 2, 2004
1,955
Oday Day Sailer Wareham, MA
I would ALWAYS remove the rudder when trailiering and whenever I leave the boat overnight. If the rudder is stowed below in the cabin there is no way it can get damaged or lost. Taking the rudder off before going ashore each night also means that you save having to paint it with antifoulant paint, plus reduces wear anf tear on the rudder and it's fittings.
Trailer boats tend to suffer much more wear and tear on the road than on the water, due to the bumps and general road vibrations and dust/dirt.
