Rudder on my 340 hunter has to much play
HD74
Dec 27, 2016
66
Hunter 340 Pickwick tn
It is allowing the top of rudder to drag on bottom. Not sure how to repair or where to get new bearings. Could use some help thanks
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
You might find these links helpful. The first includes a diagram and discusses bearing maintenance. The other two articles discuss rudder play and bearing replacement.
Hunter 340 Baytown TX
And check this thread link, too. I'm not sure if it was this site or Facebook where I saw a 340 had the same problem, only a lot worse. So pull the cockpit floor and check the top of the rudder if you already haven't.
Rudder Post Failure?
