Rudder Line Question
3
Oday Daysailer III Portland
I recently purchased an Oday DSII but it has a DSIII rudder, I took the rudder assembly apart to clean it and I cannot remember how the line is rigged from the Rudder up through the plate assembly to the tiller? Does anyone have a diagram or could explain how to run the line?
Thanks
1,944
Oday Day Sailer Wareham, MA
My DS II has the original all fiberglass kick-up rudder, so I can't really help. However, the rudder that you describe may actually be a DS II rudder, the later models (1983-85) of the DS II had a rudder with a wood blade and an aluminum top assembly (same as the DS III).
I'd say if all else fails, give Rudy at D&R Marine a call (508) 644-3001, he builds those rudders like yours and should be able to give you advice.
