I Own a 1986 40 ledend which I bougth in 2000, it has the original engine 44 hp.I was told that this engine can run at 3200 RPM'? I can only run my boat at 2200 rpm's and get around 6 knots. If I go up to 2500 rpm's ,I get a small amount of vibrations in the boat. If I go to 3000 rpm's the boat shakes everything of the shelves. I had the trans rebuilt, new motor mounts, check shaft, it is straight, cutless bearing is good. Dose ay one have the specks on the propsize and pitch. Is this the top rpm's for this boat(2000). I would like to here from other owners that migh hve a answer to this problem.
