From another forum: "I had a problem with a rat on board. I divorced him".
OK Rats big problem easy fix. I live on 5 acres and have a problem with rodants getting into my cars and setting up house and as with cars, boat can be rendered in-op because thet feast on wire installation causeing shorts and can also cause fires. I have Had the BEST luck with a organic repellant called "Freash Cab" it's a pleasant smell to humans but rodents don't like it. Go to "jefferspet.com" in search type in "fresh Cab" you'll find that it's not very expensive. If your like me in no time at all you'll be a great fan. Good luckI have a 1982 Catalina 30 that I am refurbishing. I have definitely seen evidence of mouse excrement in the cabin and what appears to be some kind of a nest or something. I'm including a photo case anyone can figure out what it is. Has anybody dealt with this before? Does electronic sound devices work? There are small holes at the bottom of the oval compartments on either side of the cockpit I'm assuming that's how they got in. Thanks in advance.
PS> Dont Posion them, why, because if they go and died in a place you cant asses you'll never get rid of the foul smell. I've also tried Bounce and that didn't work for meOK Rats big problem easy fix. I live on 5 acres and have a problem with rodants getting into my cars and setting up house and as with cars, boat can be rendered in-op because thet feast on wire installation causeing shorts and can also cause fires. I have Had the BEST luck with a organic repellant called "Freash Cab" it's a pleasant smell to humans but rodents don't like it. Go to "jefferspet.com" in search type in "fresh Cab" you'll find that it's not very expensive. If your like me in no time at all you'll be a great fan. Good luck
