I take a scraper tool and shear off the rivet head with a good sharp blow. I dont know if shearing off the heads would work with Stainless steel (guessing it might not).
Don't even think it, with SS rivets in an aluminum spar. It will ruin the hole.
What I suspected. I was frustrated on the hottest day of the year working outside in 105 deg and had to take out a few of the rivets. Took my scraper and just whacked at the aluminum rivets and off they popped. I really should have drilled them but might have been delirious from heat exposure. Having said that the aluminum ones do seem to pop right off very easily.
I avoided using the SS rivets as I wasn't sure if I should mix SS with an aluminum spar.
Do most people try to keep aluminum with aluminum and SS with SS or do we mix it up???? Just curious?
I think you will find that 3/16" SS rivets are very common. Some isolate them with tefgel or equivalent. Most manufacturers don't bother, though it is a good idea.Don't even think it, with SS rivets in an aluminum spar. It will ruin the hole.
If you are going to drill & tap be sure the mast section is at least as thick as the wire diameter of the machine screw you're using & use fine threads.. Personally I would rivet that with SS rivets and call it a day.I don't mean to be a pest about this, but the instructions for intalling the mast and boom fittings for the Spinlock Powervang, says "drill and tap", though it does not say what kind of screw they have in mind. From what I am reading here, a rivnut would be a far better fastener for a device that will be subjected to the forces normally visited on a topping lift, vang, and jibe limiter.
Did a search on Tefgel and it's a teflon gel . It eliminates dissimiliar metal corrosion.
(DUH!!for me). LOL
How is it applied when using stainless steel rivets in a 1/8" thick aluminum mast and is it necessary??? I'm just asking to learn so please be kind. I dont really understand what the risk of galvanic interaction with stainless and aluminum is and where strength of SS would be a "significant" requirement over aluminum rivets. Again just asking so that going forward I can do the right thing. Understanding why helps me to remember the correct way to do something.
If you are going to drill & tap.....machine screw you're using & use fine threads.. quote]
Some replies are drifting over to saying "sheet metal screws", and then there machine screws. To the OP, he might not pick up on what the replies are really saying. Or, Bill, are you REALLY saying 'sheet metal screws' as opposed to 'machine screws'![]()
By "oversized" I meant larger than I'd intended. I was going to use a 1/4-20 tap, but I had to use a 1/4" bit to drill out the rivets, leaving a hole too large for that tap. (A smaller bit wasn't large enough to drill out the rivet.)I don't understand some of the bias against rivets. I've certainly tapped for machine screws too, so I do understand their merits. They are stronger in thicker masts (read "larger boats") but weaker in thinner masts (read "trailer boats and beach cats"). You MUST use Tefgel on screws you intend to remove someday, though with rivets it makes less difference.
a. I don't understand why you would drill oversize to remove a rivet. I have removed hundreds over the years, in both marine and industrial settings, and never had to do that. Drill the exact size, hold it if is spins, and tap it through with a punch. Drilling over size was most likely a mistake born of fatigue; we all make them.
That is the main weakness of rivets; if you can't press everything flat and tight before expanding the rivet, the result is wobbly. A bolt, on the other hand, will pull up. Good choice.As for replacing the rivets, the issue was this: the plate for the radar mount is flat, fitting onto the curve of the mast. The result is that one part of the plate isn't snug up against the mast and the rivet didn't seem to be really tight. I must say, when I shook the radar side to side at first it had a fair bit of play. After replacing the rivets it didn't.
by the way, this was on a Jenneau 46, so the mast was relatively thick walled.But isn't that issue resolved by using rivnuts, which also eliminates the inadequate "bite" when screws of any kind are put into thin-walled material?
