P
Patrick Randall
I ordered a backstay from xxxxxx.com and gave the following description of the end fitting at the mast crane end:1. top part of backstay - 7x19 stainless 3/16" - TOP FITTING - swaged stem ball to fit Isomat crane (16.5mm across top of hemisphere - the bit that goes through the cup, the ball "cup" is 26.5mm dia, 11.8mm top-bottom) BOTTOM FITTING ..... (snip)The backstay was delivered today but there is no cup. I can't fit the original cup over the bottom swaged fork as the fork is too big. I haven't been up the mast yet (thunderstorms about!) but I suspect the stem ball without the cup will pass straight though the mast crane (or at least not be a good fit).I'm about to complain that xxxx.com didn't supply what I ordered - that is, they should have put a cup on the wire before they swaged it.Do you think that's a reasonable complaint? (I've attached a pic of the original stay with the cup in place)
