Rigging adjustment
15
oday 25 Sugar Creek Bay, Kentucy Lake
How many pounds is the rigging need to be tuned at in a 77 model 25. All my standing rigging has been replaced 2 years ago before I bought her.:confused:
RichH
Feb 14, 2005
4,773
In PERCENT tension, all rigging is approximately the same for 'plain vanilla' applications ---12-15% tension for sailing in 'moderate' conditions. Correct wire tension is important as your sail 'shape' especially the jib/genoa depends on the wire tension; as a sailmaker for 'stock' sails cuts the jib/genoa *expecting* that wire tension to be close to that 12-15% value of tension.
Do consider to use the Seldén rigging manual ... has methods to set that 12-15% *without* a tension gage.
http://www.riggingandsails.com/pdf/selden-tuning.pdf
Apr 7, 2013
15
Thanks guys for the good info. I will write these links down and review.
