Oday's rigging guide
According to Oday's Manuel, they recommend that after all stays are securely attached, take the slack out of the rigging and tighten. With the mast plumb ( in a vertical position), the headstay, backstay, the two upper sidestays, should be tightened 3-5 turns more than hand tight. Lowers should be hand tight. Hope this helps.
