Rigging tension
I don't tune my boat to any presupposed numbers. Instead, I set it up so that each shroud or stay is hand-tight (as far as I can do my well lubricated turnbuckles by hand). Then I set mast rake. Next I go back and forth tightening the head and backstays. I have roller furling so its hard to judge tension. Instead I gauge it using the backstay. The slightly different lenghts works out through quirks in geometry to slightly different tensions but its close enough to use. On my 25 I'm looking for about an inch of deflection in the stay with a 20 pound push at shoulder level. Then I do the upper shrouds. Again, I'm looking for that inch of deflection with a 20 pound push. Next the lowers, not quite as tight as the uppers. Then I sail the boat. Things are tight enough if nothing goes slack enough to risk jumping from the spreaders (which are wired anyway, naturally.)After that its a question of tuning for performance.Justin - O'day Owners' Web
