OK ...next project on the refurb ...the steaming light half way up the mast is working just fine ...but the masthead anchor light is completely dead and went to an old fuse panel (labelled up) . Ive done a continuity check on the cables in the fuse panel and its an open loop on the masthead.
Ive the undone the deck gland at the base of the mast and the wiring insulation has perished so much so that the bare wires are exposed (existing four cables in the insulation).
In short im going to replace the wires and lights for the sake of longevity, electrical safety and certainty . Tips and advice would be greatly received - from double halyards on the bosuns chair to wiring strategy . Ive heard of using the mast as a ground with the lights connected locally , using a common ground and having three wires, as well as an alternative of running a single four core cable with positive and negative for each light. Thoughts and experience welcome! Mast is about 30ft
