Ok, I've read Sailboat Electrics Simplified, and traced the existing wires to the best of my ability. I want more switches than on the original panel, so my plan is to repurposed the panel holes and add a fuse block. I have read through the book and also available C22 wiring diagrams.
I'm still left with the following questions.
Does all power run through the one master switch as I've drawn in my diagram?
If I want to add solar charging I'm not clear where to patch that in (that might be a separate thread).
I have a Blue Sea fuse block as well but it doesn't have the negative bus bar some I'm considering using this Kohree model.
