Rewiring a C27: questions
1,055
1982 Catalina 27. Mostly original wiring (including trailer hitch connectors for engine), but some work by POs. After reading a lot of postings here and there I've got a basic idea of what I want to do, but I'm trying to figure out wire sizes, fuse sizes, and what type fuses to use where.
Here's what I've got:
Universal 5411
2, 65AH, size 24 batteries
Statpower (Xantrex) TrueCharge 10TB 10A dual battery charger
Sunsei SE-500 (7.5 W, 0.5A), CC-10000 controller solar charger
1/2/B Battery switch
6 breaker DC panel, radio, stereo, GPS, lighting
#4 wire from battery to DC switch and to starter
#10 wire most everywhere else
My plan:
Wire the AC charger, alternator, and solar charger directly to battery 1. Add a Blue Sea ACR between battery 1 & 2.
Use the 1/2/B switch as is (following Maine Sail's discussions).
Rewire between engine and control panel.
Add solenoid at engine for glow plugs.
I'm thinking of putting a two post Blue Sea MRBF on battery 1: one post for the (#4?, 100A) wires to the DC switch, alternator, and ACR and one post for the (#10?, 60A) wires to the chargers. Battery 2 would have a one post MRBF for the (#4?, 100A) wires to the DC switch and ACR.
Does that seem reasonable?
Nov 16, 2012
1,055
Lots of views but no reply yet. Maybe I'll try to clarify what I'm asking.
Is #4 wire big enough for the alternator and starter? The distance is pretty short, less than 10 foot both ways, so that looks ok from the tables. Is a 100A fuse ok? I know #4 rates 160A, but I don't mind being a little conservative. 60A is the rating for #10 wire, so I feel more confident about that.
Also, is there any problem with stacking several lugs on the MRBF? Blue Sea says it's a feature. I don't know how easy it would be to put busbars in the lazarette with the batteries and it would add to the cost and complexity.
Thanks, Rob
