Okay, I guess we have to agree to disagree. If the boat had gone aground and Texas A&M had hired a surveyor and he had condemned the boat as unfixable because of design failings then I could agree with you. That's not what happened. As I read the testimony not a single qualified person was involved in the inspection or the repair of the boat. The grounding was a major event. They were towed off. Debroth passes it off by saying, essentially, "hey my boats go aground and some of them hard but they haven't had this kind of failure." I doubt he would sit in a witness stand and say "if one of my boats was hauled an had this kind of damage showing I wouldn't advise getting it inspected." He also doesn't say "when my boats go aground so hard they have to be towed off I expect them to be essentially unharmed." I think he's not being candid. He just assumes there was no laminate damage. That's hard to square with his assertion that the deeper keel and thinner panel layup on this boat made it more prone to grounding damage than a typical boat. I don't see how he can argue it both ways. The pictures he enters into evidence show substantial damage to the keel and hull both fore and aft. Those kinds of groundings can and do result in total losses of boats. The pictures show the keel broken away from the hull and the hull crushed. That's all they should have had to see to know that they needed serious expert advise. The pictures of the repair show WR on top of paint. He doesn't tell us how that can be a quality repair.
That boat should never have left the repair yard in that condition. There are design issues and construction mistakes, but fact that a school would allow its staff and students to hack together a repair on the most critical area of a boat that they intended to send their kids to sea in is unforgivable to me.
--Tom.
There are a few issues here that need to be clarified.
First, the Cynthia Woods is not a high performance ultra light racing boat. It is, at best, a high performance cruiser. Given the class of boats it raced against, the race committee's would agree. The prototype, a boat the company referred to as a shoal draft cruiser, actually had a faster PHRF #. Why? A similar boat in construction to hull#1 has won Key West Race Week and done well elsewhere. Although the boat sails against Hunters, O'Days and low end Beneteaus as well with a gifted slow rating. Again, why? Now I am not knocking the boats mentioned, they are not performance racers, as the CF38 is not.
The target boats were J105's and J109's with the "shoal draft", which is a term I never heard used describing my boat. Funny how the Ultra light race version suddenly needs to race against the boats mentioned. Please don't get all worked up because I mentioned those boats, they just are not performance boats. It's like racing a Greyhound against a Yorkie.................
I know this because I owned the rights to the boat, just hated the end result they had me create. So I sold a turn key operation to the guy to begin building "parts" which assembled, resembled a sailboat. They were unable to modify their own molds to create stadium seating and a user friendly cockpit. Why? Because they are not able to, simple and true.
The hull thickness: USCG reps measured the shim and hull, faking a greater hull thickness, which is far less, 1/2". Now that keel was changed for one simple reason. To aloow multiple depth options using one cord. Mars Keels charged at the time roughly $200/year/keel plug. Mitchell refused to pay the multiple storage fees and instructed Marek to design a onw size fits all keel.
YES, a solid lead keel is SIGNIFICANTLY different than the standard steel strut/lead bulb modern keels. Not only was that keel a huge chunk of lead, it is a low performing section, ultra NONrace configuration. I build high aspect carbon keels and rudders, I am an expert.
The keel bolt pattern had to be changed because they made the cord too thin for a proper bolt pattern. The pattern has not been mentioned, but an inline pattern of over sized bolts is weak. The 3" hull thickness described earlier in this topic is based on the bolt size and standards with regards to the relationship of hull thickness to bold size. Given the exteme size of the bolts, that hull would need to be 3" thick. Easy and end of that........
Laminate.
The boat was not bagged. It is also a combination of vinylester resins, to allow gelcoat and epoxy. The laminate also has incorrect fiber orientation, a mix of kevlar, that did nothing but add bulk, bulk that did not extend the laminates performance, yet decreased it. Hull thickness as measured by the USCG expert included materials not related to structure, yet implies such.
It's not rocket science, add more materials to the structure, tie those floors to the bolts. Install proper backing plates that won't saw the laminate to failure.
It's also insulting to continue calling that boat an ultra light, the actual weight was in fact much heavier than advertised, most likely because the boat was wet out using a chopper gun.
Looking at the photos, it also appears the boat has very little epoxy resin. A good thing if true because mixing resins of differing thermal expansion rates is stupid.
I know it's impossible to change someones hellbent intention to blindly follow the USCG and for some reason think a company that built less than one boat a year in it's short time is useless. However, the USCG is wrong here, dead wrong. CFYW sent that expert just what they wanted in the report. I have the original drawings, the USCG expert never asked for them to compare the alterations. I was more than happy to present those documents to the TAMU expert, who actually came to my shop for an interview. Never even recieved a call from Kiko, although I sure did give him an earful. Poor guy, he should have done his job!
Agout that stellar production company. Mitchell was quoted saying I was a one off advanced compsites expert who did not understand production building. Well, I build the production molds, built hull #1. Since then they built 6 boats, three "regatta" versions. One of those was built to original hull laminate, other two were the altered laminate boats donated to a school they knew would be extremely rough on the boats. One boat was a shaol draft boat, it was their first boat out of the mold. The boat was a heavy heavey boat, with transom an 1" under water.........yikes. That boat was dumped in my lap in Newport before a boatshow in 02. After making the boat show ready I travelled to the shop to see what they were doing wrong. I was Son Of Boomer with it's slab hunk of lead and went completely berzerk, melting down before their eyes. They had latered the keel boss and the keel sat on that UGLY shim.
The rest is internet history. I wrote about the boat on boatdesign, with many photos.
Tamu is destroying CW and sending GP back to the builder. THAT is the most amazing mistaek to date. Give the bad guys the only remaining evidence. Take GP out in big weather and sail it to see if the keel falls off. I'll do it in a heartbeat, with a rescue boat close at hand........... and just me, Marek and Mitchell. Come to think of it, no rescue boat.
Son of Boomer was destroyed in a hurricane last year. Same ugly laminate shards in those photos.
So, here's a "production" company touting their (well Mitchell's clain, remeber he had not seen wet resin before I built his boat........made it look too easy I think) production expertise (OH btw, they skipped hull #'s to imply greater #'s.....who does that?) and they lose 3 of their 7 in total boats. ONE I built, so it can be said they lost have their production line to failure and returned product. Not such a success story is it? I would love to hear the spin/twist on the facts.
Back to grinding carbon.
Yesterday I raced with my 86 year old father in the Mystic River Mudhead Hospice race. We won the event in our 40 year old Ohlson 38. I couldn't help think how lucky I am to be able to spend such a wonderful time woth my father............think of the Stones please.
Always question authority, PARTICULARLY the USCG who had to go outside their own entity to find an expert!
