Don't assume the Coast Guard is disinterested and therefore the expert they hired is objective. I've seen the Coast Guard insert their agenda into an inquiry. The expert they hire could also have an agenda they aren't aware of. The marine community is relatively small. I'm not saying this was the case here but just pointing out that the theoretical structure of the Coast Guard hiring an "expert" does not guarantee an impartial report in the real world, at least as I've experienced it in similar situations that I was much closer to. Each report should be judged strictly on its own internal merits and not by its source.Except for the Coast Guard report the only evidence we have is from interested parties ..
I don't know the grounding loads and impacts. I'm not claiming that a typical keel attachment or even an industry best practice design would have survived whatever abuse this boat had without damage or weakening. I will assert however, that such a keel attachment, i.e. one that would be the last thing to fail as the boat could was pounded and dragged, could be designed. Such a design would have minimal impact on performance and cost. This is one of the few areas of the boat where the weight distribution issues make such very conservative construction possible. Few, if any, builders are taking advantage of this fact. However, an understanding this aspect of vessel design (deeply rooted in stability and weight distribution which are one of my primary areas of expertise) makes the design of this keel even more appalling.We part ways again. You assert that a boat designed and built to best (or at least good) practices would have withstood the abuse.
I will fully accept the possibility that there are other production or custom boats that could have experienced this failure scenario with the same service history. I sure hope there aren't many designs as bad as this one out there but I'm beginning to suspect (largely because of how Richards assessed the keel design) that there may be. I simply haven't looked at that many fin keel attachments.
