replacing throttle cable 1983 hunter 31
1
Hunter 31_83-87 jacksonville beach, florida
would appreciate instructions on adjusting newly instatlled throttle cable from meriman pedestal to yanmar engine. thanks will make it up to you..
Dec 23, 2003
268
Hunter H31 83-87 Captain's Cove Bridgeport, CT
Just Did Mind
Here the thread I posted last week. For the position of the throttle handle linkage arm, if looking at it from the side, idle position is at 8 o'clock and full throttle around 10 o'clock. The clevis is screw down till the threads just show from it's top. Then adjust the the cable using the clamp in the tube to get that 8 to 10 movement and lock down the clamp. the final adjustment is made at the engine by tighting or looseing the threaded rod into the clevis. Make sure you get full open on that lever. Set idle at 800 rpm's. Hope this helps.
