I have a worn out motor bracket on my boat that I have tried to fix, but my fix is just not going to work out. I went shopping tonight and bought the Garelick mount - see link. Oh, I should mention that I have the 8hp Honda 4 stroke motor.The holes line up fine with the old holes already in the transom, but the handle on the mount is almost flush with the mount so I'd have to shim the mount out a bit. After staring at it a while, I find that I would have to put a block about 3-4 inches thick to get the mount out far enough to operate the handle! I'm thinking of returning the mount and getting something else. I did see another Garelick mount that was less expensive and would hold up to 115 lbs and 20hp....but, they say it is only for 2 stroke motors, and the holes would have to be modified to fit my existing transom holes. I'd like to avoid drilling any more holes in the boat (I found a few more that were used in the past and filled.)So, should I just give up and get the 3 spring mount from Catalina Direct? Modify the cheaper Garelick (it's model number Mfr # 71056:01 - Google it!) mount to fit my holes? It says it's not recommended for 4 stroke, why is that? More twisting torque?Anyway, I'm just a bit frustrated at the moment for spending the evening staring at the back of my boat. *sigh*Ideas?Tom
