Now is a good time to learn about Main sails
Vin,now that you are in this position, it is a good time to learn about main sail. I would do a compare all the sails I inquire about.1. Material weight.2. Type of material and it's specific qualities. The cloth is made in so many ways, find out what you are buying. Some are designed to be stabile in both directions and some have flex in one direction. Some are a tight weave and some are actually loose weaved and filled with rosin. The cloth is often weaved by one manufacture for many end product finishers. I am saying that different companies finish the cloth in their own way, combo of rosin, heat, etc.3. Reef points.4. Adjustability for flattening or max shaping. Ability to move the center of effort forward or back. Vin, know this, with the high aspect main on the 25, I sail almost as fast without the main as I sail with it. The 25 main sail needs to be adjustable if it is going to make a difference in how the boat performs.If you are up grading, ,ake sure you are upgrading.r.w.landau
