Replacing Ports - H34
Jun 27, 2004
113
Hunter 34 New Bern, NC
Has anyone tried replacing ports in a Hunter 34. I have a 1986 H34, and I am considering replacing the Gray Marine ports with Rain Drain Ports from Beckson. I am curious to see if anyone has already tried this.
Thanks,
Fast Ed
Jul 28, 2013
126
Hunter 34 Holland, Mi
I have changed mine to Beckson ports. The only real issue is that the drains are in different locations. You will have to fill the existing drains and cut out for the Beckson drain locations. I think it is worth the effort. The Beckson are much nicer.
Nov 5, 2009
62
Hunter 34 Quebec
Yep I replaced the old plastic ports for Bomar aluminum. They were slightly bigger so had to re-size the holes with jigsaw and either metal or carbide blade (neither work really well because of the wood/fiberglass mix, but it eventually does the job)
And then I also found that, to my aesthetic taste, the boat had too much ports and removed the forwards ones and rebuild the deck in those place... not the most useful job onboard but well, I like it now;P
PGIJon
Mar 3, 2012
856
Hunter 34 Punta Gorda
After cutting for the new holes and drain holes, how do you fill the voids? Thanks.. Jon
