On my 2000 340, I have a Ray52 VHF radio. The cord has deteriorated and as it is hard wired to the unit it cannot be replaced.
What I would like to do is remove it and replace it with a Handheld Unit, outside in the cockpit area, that can be attached to the existing Power and Antenna cables and eliminate the Ray52 radio all together.
Are new Raymarine VHF's (or any) radio connections compatible with the old in mast wiring harness?
Are the Handheld models stand alone units or do they need a base unit elsewhere on the boat?
If I do need a base unit I would like to relocate it to the Nav Station in the boat.
I can cut the original wires (power and antenna) in the boat (once I find the route they take) and splice a new wire to them.
That's why I am thinking a Handheld Unit would make a better option, or will I need to rewire the boat for a new radio?
This is a much needed upgrade to the boat. Anyone done this? Thank you for your help.
