Has anyone replaced the oil sending unit on the Hunter 49. It's at the back of the engine, can it be replaced without removing the engine. It seems impossible to get at.
I assume you are talking about the oil pressure guage.Has anyone replaced the oil sending unit on the Hunter 49. It's at the back of the engine, can it be replaced without removing the engine. It seems impossible to get at.
Ok, here's the scoop.Yes the sender for the oil pressure gauge. I have taken the air intake tube off from the turbo now I have chance on getting to the sender. Need a 14mm foot wrench.
Do you have a low oil pressure horn. If Hunter put one on mine has never worked.
I did your access mod. last year. I have the Yanmar tool for removing the impeller, it works great!
