If there is anyone out there who replaced the waste pipe on a Hunter 340, I could sure use your help! To make a long story short, the waste pipe (i.e. the 1 and 1/2" black hose that runs from the head to the waste tank) on my 1999 Hunter 340 needs to be replaced. It was easy enough to disconnect the old pipe/hose from the tank and the toilet but I can't seem to figure out how to pull it out so I can put in the new one.I tried pulling the old pipe from one end and then the other but I can't seem to budge it. No matter what I try, it feels like something is holding it in place. Since I can't see in between the shell and hull to locate the problem, my guess is the hose is either: (a) jammed between the inner shell and the hull at some point or (b) it is somehow anchored in place.The problem is, I can't figure out a way to get at the old pipe to free it without cutting a hole through the inner shell and then sticking my hand and arm in to find the trouble spot. I'm sure it's no surprise that I really don't want to do that, especially since I don't know where to cut the hole in order to reach the problem.If anyone has any experience with this subject, I'm all ears!
