In the process of changing the coolant hoses from the engine to the water heater. On one of the hoses at the water heater there is a plastic inline bleed valve. I have never used this when bleeding the air from the system after changing coolant. It is in a location where it is not easily accessible. All of the bleeding I have done is in the engine compartment. Any reason why I can't just eliminate this valve and plumb the hose directly to the fitting on the water heater. It would make installation easier. as I said earlier I have never even turned this valve.
Thanks,
Mark
Thanks,
Mark
