I need to replace a leaky hose that runs from my cockpit drain fitting (the white plastic through-deck that's on the transom bulkhead in that little sump on the aft-most part of the cockpit where water collects) to the white through-deck fitting on the outside of the transom. I poked a big hole in it thinking I was clearing a clog. She's a 1979 O'Day 25.
It looks difficult, if not impossible, to reach it from either engine access hatch. Has anyone tried to crawl back there?
If it isn't possible (or I risk getting my butt stuck in an engine compartment for the winter), does anyone have any suggestions? I'm thinking about cutting an access port into the bulkhead just above the cockpit fitting, but I'm not sure I'd be able to reach the hose and the clamps.
The boat's on her cradle for the winter, but I need to get this done before the snow starts flying and melting and water flows from the cockpit into the engine compartment. Anyone have any experience or ideas? Even a temporary fix that lasts until spring would help.
Thanks
Thanks
