Ok, thanks so much! May I ask, what do you mean by, "you still need to decore it for the required length"?
Basically, we are new owners of a Catalina 25. The genoa needed repair so we took it down and had it repaired. When we put it back up, we thought we would be "smart" and use the regular jib halyard. Only once it was all back up did we realize the regular jib halyard won't work because it twists at the top. So we realized we need to use the internal halyard. But it's too short so we need to replace.
Now we are trying to make sure all our ducks are in a row for when we drop the mast again to replace it.
I guess my biggest confusion is this: if the halyard is only like 36' (which seems to be the CDI replacement), how do you have enough line to raise the genoa? Doesn't there need to be enough line to go all the way up the mast and back down?
So thankful for all the help!
