replacing a broken or cracked thru hull *666
643
SCHOCK santana27' lake pleasant,az
your boat is in the water, a thru hull is leaking what do you do??? o.k. its broken before the valve and needs to be replaced while the boat is in the water GO! *yks
Sep 19, 2006
643
Shane
Wood Plug
Quickly put the wood plug in to stop the water. (You do have a wood plug tied to the valve don't you??) As far as replacing in water can that be done?
Shane
Wood Plug
C
caguy
I learned after jury rigging a plug that
a rag with bees wax will plug just about anything. If the hole is just below the water line I imagine that the boat can be heeled enough at the dock by pulling on the mast or weighting the boom, to get the hole above the water line for repair. Have you seen that commercial on TV for an epoxy putty. Looks like it would work under water. Frank
C
caguy
May 11, 2005
3,431
Seidelman S37 Slidell, La.
You might try
I think I would try a plumbers test plug, available at HD/Lowes etc. They come in all sizes, and are pretty strong material. Stuff it in the hole, air it up. Should hold back any leak, until you can fix it right.
May 11, 2005
3,431
You might try
Jim
May 21, 2007
775
Catalina 36 MK II NJ
Get a short hull ASAP
can the bigle pump keep up with the water? If not wood plug.
Jim
May 21, 2007
775
Ross
Jun 15, 2004
14,693
If you have enough tidal range you could ground
the boat at high tide and careen it and change the thru hull that way otherwise you must have it hauled. If the thru-hull has been installed in the manner discribed by Maine Sail then the thru-hull won't need changing just the cracked fitting above the thru-hull.
Ross
Jun 15, 2004
14,693
Tom S
Feb 4, 2004
172
Catalina 36mkII Stamford, CT
Are you talking Thru Hull or Seacock that is spun on top of Thru Hull
I don't see in how you are going to replace a thru hull with the boat in the water unless you do what someone suggested and try "beach" the boat near high tide and then try and get the job done while the tide is out. If your Seacock is what needs to be replaced and you can spin it off the Thru-Hull without damaging the integrity of the thru-hull caulked/bonded to the boat(as you should be able to do). Then you can do it with the boat in the water. Just need wooded plugs. I just did it. Its a bit disconcerting to have a huge 2-3 foot gush of water come up through the boat but those wooden plugs work well. The procedure is straightforward. Spin off old broken Seacock, plug Thru-Hull with wooden plug, put teflon Tape threads on Thru-Hull, pull wooden plug and then quickly spin on new Seacock.
Tom S
Feb 4, 2004
172
Mike B
Apr 15, 2007
1,013
Beneteau 43 Baltimore, MD
Put the lug in the outside
He's in Arizona so the water should be plenty warm enough for him to over the side and insert the pulg from the outside. If he does that prior to removing the fitting he shouldn't get any more than a small amount of water in the boat. Just have to make sure the plug is in firmly.
Mike B
Apr 15, 2007
1,013
Dec 8, 2007
478
Irwin 41 CC Ketch LaConner WA
Mike has got it
as it was stated that thru hull was broken befor the valve. Your going to have to get wet on this one!! Then do as Ross and others have said " Replace it high and dry one way or another.
Dec 8, 2007
478
Mike has got it
Benny
If you have to remove the the through the hull
and replace, take the boat out of the water. If you just have to replace the valve you may take a chance that the through the hull bond desn't break but best if you take the boat out of the water.
Benny
