replacing a broken or cracked thru hull *666
643
SCHOCK santana27' lake pleasant,az
did you know ???
some rubber cement will set up under water??? (test it before you need to) how about a rubber patch slapped over the thru hull from the out side till you can fix it proper??? this is how i did it dont have a bilge pump or the time to return to the marina for help it held for 2 days of good sailing p.s. dont use plastic thru hulls when you trailer your boat
Sep 19, 2006
643
did you know ???
higgs
Aug 24, 2005
3,738
Nassau 34 Olcott, NY
No brainer
If the leak is at the actual thru hull the boat will have to be pulled to replace the fitting. No way around it.
