Have any of fellow Bavaria owners replaced the original cabin lights with LEDs? I believe the lights are pretty much the same in most Bavarias - 24V, 5 amp. Would be nice to replace just the bulb and not the whole light fixture. Thanks!
The G-4 Cabin Light "The Brick" from cruisingsolutions.com is a perfect LED substitute for your current halogen cabin light bulbs. You won't know the difference except that you'll be able to run all your cabin lights on the same amount of power it now takes to run just one cabin light and you fixtures won't get hot any more.Have any of fellow Bavaria owners replaced the original cabin lights with LEDs? I believe the lights are pretty much the same in most Bavarias - 24V, 5 amp. Would be nice to replace just the bulb and not the whole light fixture. Thanks!
