replace propane stove
96
Hunter 30 Groton, CT
I have an Hunter295, its stove is shot and I need to replace the whole unit. Anyone have experience with such a project? Seems, like remove the microwave and access from that cavity.
Cheers
Jun 25, 2012
942
hunter 356 Kemah,the Republic of Texas
Cheers
Post pictures....So we can all see what you are looking at.
May 1, 2009
96
Yes I believe so. The portlight above the unit had leaked so the valves are corroded
Nov 6, 2006
10,257
Many of those parts are standard gas stove parts and you may get lucky by taking the bad parts to a good appliance parts store and talking to the guys there. I had to replace my oven thermostat/gas valve and found it was a standard Robertshaw part that Seaward had used. Don't try that unless you are skilled in assembling and pressure testing the resulting work..
Jun 25, 2012
942
Is it a Princess (Seaward)?
Soooo its Electric? Glass Stove top model...2 burner or 3 burner?
Why don't you just replace with the same model?
Or do you just do not like it?
Maybe all it needs is a good servicing and internal cleaning.
If this info helps. I have a gimballed mounted seaward gas range with broiler. 10 years old and bakes better then the oven at home. Love it!
I take more pride, enjoying cleaning and polishing it up then home.
