Replace just acrylic on bow deck hatch?
Jun 11, 2020
32
Hunter 29.5 Northport
I have a 1994 Hunter 29.5 and the acrylic on the bow deck hatch cracked. Can I have someone just replace the acrylic, or do I need to buy a whole new hatch? Looks like it is a BOMAR 1039. About 20" opening.
The acrylic can be replaced. Contact Bomar they may have on precut and drilled. Or you can go to a local plastic supplier and have them cut or TAP Plastics.
Check the Hunter store here at SBO, they may stock the new lens.
Likes: william24424
Nov 6, 2020
589
Mariner 36 California
Try and get the old piece of acylic out without breaking it into smaller pieces. Bring it to a local plastic (acrylic) fabricator. Probably can get a new piece cut to the exact same shape for under $100. Pretty easy to install in an afternoon. 1/4" thick bronze acrylic runs about $15 a sq./ft for material.
Nov 6, 2006
10,244
I replaced mine 8 years ago. I used TAP Plastics ; they cut the replacements perfectly and the price was good.. That order was for two small Bowmars and a small flat cover on a deck cubby.. Measure precisely or as Bad Orca says, carefully remove the old lens and take it to a local shop .. I used Dow 795 to rebed the new lenses.
Transparent Acrylic Sheets (Cut-to-Size) - Transparent Smoke
3/8 (.354)" Thick, 10-1/8" Wide, 10-1/8" Long
$14.24
$28.48
2
99810
1" radius cornering for Transparent Acrylic Sheets (Cut-to-Size) - Transparent Smoke3/8 (.354)" Thick, 10-1/8" Wide, 10-1/8" Long
$5.00
$10.00
1
99999
1/4 (.236)" Thick, 15" Wide, 7-1/2" Long
$11.46
$11.46
Subtotal
$49.94
UPS Ground (5 business days)
$12.69
Tax
$0.00
Total
$62.63
Dec 28, 2015
1,945
I reset my panels a bunch of years ago with the Sitka system. This includes two primers (one for aluminum, one for the panel) and the adhesive. It has been rock solid.
