Replace aft sanitation hose.
Apr 29, 2018
3
Hunter 420 San Diego
Anyone ever replaced aft sanitation hose from head to vacuflush pump, How to access.
Hunter 420 Passage center cockpit.2003.
Thanks
Dec 2, 1997
9,011
- - LIttle Rock
I see you've just joined our merry little band today...welcome aboard!
I need a bit more information to answer your question...about how far is it from that aft head to the vacuum pump? Does your VacuFlush system consist of 3 separate components--bowl assemby, vacuum tank and vacuum pump, or are the vacuum tank and vacuum pump combined into a "vacuum generator." Are both toilets connected to a single HOLDING tank, or is there a separate holding tank for each toilet? And finally...do you know where the vaccuum tank and pump or vacuum generator are located in the boat? 'Cuz knowing that will be the first step in figuring out how to replace the hose without taking the boat apart.
Apr 29, 2018
3
Two systems forward and aft, Seperate holding tanks, I am replacing the hose from the toilet to the inlet on the vacuflush system that is located in the aft port septee.
Dec 2, 1997
9,011
- - LIttle Rock
In that case, replacing the hose shouldn't be that difficult. You only need access to both ends of it. Disconnect 'em (warming a bit with heat gun, or better yet a blow dryer will be make 'em much easier to remove...be careful, you only want to WARM 'em, not melt 'em!), connect the new hose to the old using a male-male connector and pull the new hose through as you pull the old hose out. Secure ends of the hose to the connector using PVC cement or superglue...hose clamps can get caught, duct tape won't hold if you have to tug on the hose. Cut the new hose off right behind the connector and connect both ends where they belong.
Oct 24, 2010
2,405
Hunter 30 Everett, WA
Welcome to the best forum on the web. You may not know it yet, but Peggy is the authority on sanitation systems. So you should be real happy to have her input. I know the rest of us are.
Ken
