I have a 1989 Hunter Vision 32 and I feel I need to replace the main 30 amp breaker Alll of the off the shelf breakers for this capacity seem to be double pole My issue is that I have two 30 amp breakers inside my panel .One has a throw switch and the other one does not They appear to be cross wired I would really appreciate any information o r advice on this isssue
If I replace with a double pole breaker I will have to drill a hole for the switch and two for the bottom breaker My unit appears to be one solid unit with two breakers and one throw switch Totally confused Help needed
Thank you
Ed
Thank you
Ed
