renaming boat
15,184
Yup. If the temperature is warmer it works better. Sometimes it takes a couple of applications.
Mar 20, 2012
3,983
Does oven cleaner work on paint
easy off oven cleaner will help remove most types of paint... but some of the special epoxy or polymer paints it wont do anything for it, and its safe on fiberglass...
Mar 20, 2012
3,983
The Hailing Port is normally the usual location of the vessel. However, in reality as long as what is on the vessel matches what is on the documentation it really does not matter much.
the hailing port can be either your home town or the town where the boat is moored... or anyplace else you would like to see named on the vessel. there are probably as many who use their home town as their are that use the name of the town the boat is moored in.... either way, it wont match if you move or moor someplace else, but it will still be legal.
RECESS
Dec 20, 2003
1,509
Catalina 27 . St. Mary's Georgia
We used Easy Off Oven cleaner. It left a haze on the glass on the stern.
Jun 17, 2007
402
MacGregor Mac26S Victoria Tx
If you send me $50.00 I can have it properly done for you. Will even send you the empty champagne bottle.
Gunni
Mar 16, 2010
5,937
We will be changing our boat name and adding the hailing port in a few weeks. As a licensed vessel, the only crucial identification on the boat is the alpha-numeric designation on the bow.
However, I'm wondering whether the hailing port should be the location of the marina or the location of our home. I'd appreciate any guidance.
Thanks.
If you are simply registering the boat with Maryland, you don't need to place a hailing port. That is a requirement of USCG Documentation. Documented boats don't get bow numbers.
Pearson 26W Marblehead
RE naming a vessel
when I bought my 25 year old boat there was no name or hailing port anywhere on It I named the boat. That was 13 years ago and to this day I do not know if the boat was ever named prior to my owning it
Catalina 310 278 Lyndeborough NH
What is the minimum needed to do when renaming your boat to continue with good luck . We all know you cannot remove everything with the old boat name on it
The best way to continue with good luck is to make sure the maintenance is complete and that the crew is sober and fit.
Have the renaming party if you want - but it is just superstition in my opinion...
Bonzai
Jun 23, 2009
250
Chris-Craft SailYacht 35 St. Simon's Island, Ga.
Oven cleaner works wonders on ethanol gummed outboard carbs! Not sure on the paint removal.........Maybe need a new thread for this...lol
Mar 19, 2013
75
Beneteau First 38 Chicago
I tried Easy Off on my 1984. I'm not sure what kind of paint they used but even with a plastic scraper it was a bear and not very effective. Very little came off. I then tried a wet sand and the gelcoat was much thinner than I thought. I'm going to have to have a body person look at it and probably respray the transom.
Ross
Jun 15, 2004
14,693
Anchorclanker, As I recall the translations are a bit vague some say, " you shall have no other gods before me". There is even a movie titled,"Children of a lesser god" . And then there is Mother Nature. ;)
RECESS
Dec 20, 2003
1,509
I need to say I did not mean any disrespect towards anyone's beliefs. I posted that tongue in cheek.
I am a card carrying Injun. I think some traditions need to be preserved, around the sacred square and circle, and nautical traditions as well. I really do not see traditions running counter to religious beliefs.
Jul 13, 2010
1,100
Precision 23 Perry Hall,Baltimore County
Back to the hailing port briefly..you can walk aound any marina and see hailing ports miles away from any serious water..
