R robert Jun 2, 2005 #1 What is the best way to remove wood plug so as I can get to the screws that hold the wood on the boat??? thx for any tips.
sailaway78 . May 11, 2005 3,431 Seidelman S37 Slidell, La. Jun 2, 2005 #2 Plugs Just run a small wood screw into the center of the plug. Then you can just pop it out.
P patrick . Jun 7, 2004 944 Birch Bay Washington Jun 2, 2005 #3 Get a long sheet rock screw grind off the head and chuck it in your drill. Just center it in the plug and run it in. The plug will split cleanly and be extracted in the process.
