Removing the dodger
The demo guys use a hacksaw or a sawzall I suspect you may want a less destructive approach.
In that case a power screwdriver will remove the screws that attach the pipes to the deck. With the screws gone you should be able to lift the dodger free.
If you have it in tact and off the boat the frame may be worth something to another boater.
Good Luck.
Mar 27, 2024
2
Pearson 31-2 City Island, NY
Thanks, appreciate the advice. The same goes for the Bimini. The frames for both are in good shape but the canvas is not. I realize both are necessary but cumbersome.
