Remove Soundproofing Adhesive?
Pinch
Mar 30, 2009
23
Beneteau 361 Lottsburg, VA
I'm replacing original engine compartment soundproofing (foam with mylar sealant) from 2000 Ben 3.61 and having difficulty removing residual adhesive after getting the old foam insulation off with razor scraper. Any recommendation for adhesive removal product that really works? Unsuccessful attempts so far included DeBond Corp Marine Formula and 3M General Purpose Adhesive Cleaner 08984. Admittedly, these were done in pretty cool temps, but neither cut the old adhesive very well. Any suggestions appreciated. Thanks, Pinch
Goof Off
Good luck.
If you're going to replace the insulation, perhaps a complete removal may not be necessary?
Nov 23, 2009
437
Beneteau Oceanis 361 Clipper --
I would be very very interested hearing the results after you finish the whole job.
Good luck with your job.
Pinch
Mar 30, 2009
23
Stu
Original too deteriorated to leave on - new wouldn't adhere. Pinch
Mar 3, 2015
9
Hunter 280 Oakdale
hush mat works great and you do not have to remove the old glue, it will go over everything. it is for car and not cheap, but not hearing the engine of a sailboat is priceless
Dec 29, 2015
80
Beneteau 473 Mukilteo WA
Acetone will dissolve the old glue very quickly, but be sure to have plenty of ventilation.
Dec 29, 2015
80
Dec 29, 2015
80
Pinch
Mar 30, 2009
23
Thanks to all for comments. Contacted Soundown folks who sent helpful instructions AND indicated there was no need to remove all prior glue, as long as no loose foam material remained. So I'm taking their advice and pressing on. Will post results later. Pinch
