Removal of toerail to inspect for leaks
Dan O
May 11, 2006
3
- - Navarre, FL
I have noted other forum messages about leaks in the deck to hull seam in the stern area for the Hunter 260 when the boat is healed over or when it has a heavy load of passengers. I believe my 1999 Hunter 260 has this type of leak problem. The solution for stopping the leak was to remove the toerail in the stern area of the boat and inspect for cracks. My question concerns the removal of the toerail in the stern area of the boat. What is the proper method for removing the rubber part of the toerail to inspect for leaks? What is the proper method for reinstalling the rubber part of the toerail after completing the inspection? When inspecting the rubber part of the toerail, there does not appear to be an easy method of removing the rubber toerail. Thanks for any help.
C
Chris
Do you mean RUB rail???
The rub rail insert comes out with gentle prying from one end, under an end cap. While I am not familiar with the 260 (I sail a 23), they are all similar. After removing the insert, undo the gazillion screws that hold the rail to the boat. Good luck.
Dan O
May 11, 2006
3
- - Navarre, FL
Rub rail removal
Thanks for the advice. Yes, I meant the removal of the rub rail. Not sure why I used the the term toerail.
