reliable water pumps
Nov 2, 2015
196
hunter 30 bat n.c.
Hey.Can I get some advice on a good 12v bilge pump mine seems to have run out of strenght to pump mine out
capta
Jun 4, 2009
5,101
What do you have?
I've rarely had a Rule submersible pump fail on me.
But it really depends 0n where the pump is located. Sometimes a pump needs to be located away from the pick up and in that case a diaphragm pump is useful.
Jabsco/Par, Rule and Whale all make reliable pumps, so I guess you should choose your pump to suit your needs.
Oct 29, 2005
2,366
My experience with bilge pump is the cable joint corrosion. Pump cables are usually not very long hence joint almost always are made in bilge area. So have a well made joint and waterproofing goes a long way.
Sep 23, 2009
1,480
A good place to start is the review section on the wm site. My boat came with a dead Rule pump. Sure enough, that particular Rule had universal bad reviews. I am not happy with the current Attwood pump as it is designed to leak at the output to "prevent air lock " which unnecessary lowers output as the uphill run of the discharge hose prevents airlock anyway. My plan is to find a pump with a traditional water tight seal after checking the wm reviews. Whale and rule will be at the top of the list.
Nov 2, 2015
196
hunter 30 bat n.c.
Thanks, I think mine has lived it's life had worked fine for a long time just all of asudden not enough power to make the last of the uphill push
Oct 6, 2007
1,179
Hunter H30 1982 Chicago IL
Assuming you already checked for debris blocking the intake and any possible new kinks or obstructions in the discharge hose, and it really is kaput. I'm curious how old is the pump and what brand?
I installed a new Rule bilge pump and separate float switch in 2007 and both are still doing fine, so I would definitely recommend Rule.
Nov 2, 2015
196
hunter 30 bat n.c.
no blockage in pump or line I took the high end loose and blew back water went downhill just fine
