While the C36 MK I is wrapped this winter, I removed the exterior teak handrails to sand down and refinish (Sikkens Cetol Natural Teak and Clear Gloss) in the warmth of my basement. Very happy with the results. My plan is to reinstall the handrails this weekend.
What is the best method of 1) cleaning the non-slip areas on the deck around the foot print of the handrails (removing ~25 years of debris and varnish/Sikkens buildup) and 2) reinstalling the handrail? Would covering the bases of the handrails with butyl tape (aka - Maine Sail) be the best solution? I am worried that the tape would be too thick and not compress. Should caulk or another type of sealant be used? The temperature will probably be 40 F. While the holes through the deck are open, should these be coated with epoxy then redrilled? Lots of questions .... but I would like to do this right the first time.
Thanks.
Thanks.
